Lino Cabin Sole?
CaptainBob
7 Nov 2007
North Yorkshire
www.yacht-forum.co.uk
Thinking of trying lino for the cabin sole. There's some _ok_ looking wood effect stuff that colour matches nicely.
But I'm concerned it might be slippery when wet?
And what's a good glue to use onto the glossy gelcoat down at the moment? Something that holds lino well, but which will allow me to peel it off in the future when/if I decide to change it for something else?
TY
Real linoleum as made by Forbro Nairn with linseed oil etc has fairly good slip resistance, we used to specify it for schools, community centre lobbies, etc, but it is usually solid colour, quite thick, stiff and expensive, you make the pattern by cutting other colours into the sheet. Non slip versions have an abrasive powder in the filler, Something with an imitation wood appearance like in your grannys hallway is less likely to be Lino, though for decades shops have been selling cheap flooring of that type as 'lino' and it will be more likely to become slippery. It may be embossed vinyl sheet like Amtico and the embossed pattern will help grip, if the pattern is just printed not so much. Get an offcut sample wet it and test it, preferably at a pitch of around 30 degrees. Many years ago we used to have vinyl coated cork tiles in our bathroom, they had faily good slip and water resistance and a warm feel and appearance.
I've seen stud rubber tiles used with good effect. Good non-slip, comfy for bare feet, and a wide colour choice. Quite expensive though.
