KAL
Can anyone advise on the typical lifespan of standing rigging for a boat used as a normal cruising yacht (no racing)?
The snag with stainless steel is it 'age hardens' even when not being given a hard life.
Nonsense. Age hardening is a very specific metallurgical process requiring two heat treatment cycles,
We live and learn (providing our natural span isn't shortened by apoplexy) ;-)And I thought it was the process by which all forumites slowly became grumpy old gits.![]()
Nonsense. Age hardening is a very specific metallurgical process requiring two heat treatment cycles, typically to between 200 and 300 C. It is also known as precipitation hardening, used in superior stainless steel alloys such as 17/4 PH. The hardness of 316 stainless steel, usually manufactured in a work hardened condition for cables, rigging fittings, etc will remain totally unchanged throughout their life.
Virtually every rigging failure that you or I will ever see occurs due to fatigue. Cracks initiated at stress raisers, such as swaged ends, turnbuckle changes of section, holes, etc.
Not nonsense, and you are not the only trained engineer in the world.
The clue is in the word 'age', nothing to do with tempering or other heat treatment.
Vyv, does the use of swageless ends make it less likely to be a stress raisers or does their use give rise to their own set of problems?
If so, what are they?
So you think the properties of metals change as they get older?
There are a few cases in which the hardness of alloys increases, after very specific prior heat treatment, aluminium-copper being the best known example. Certainly not in 316 stainless steel.
