Chalker
Several replies have mentioned grab bags.
From my recent experience of choosing a liferaft they are only available with a "<24 hour" spec packed internally, including our very expensive self righting Viking.
As the "> 24 hour" spec requires a grab bag, why does no one provide a lanyard to attach the grab bag to the liferaft?
The problem of getting into a liferaft alone is bad enough, trying to do it with a grab bag would result in large number of lost grab bags. Using a clip to attach it to the liferaft pull line is fine if you remember to recover it before cutting the line! Good chance of forgetting that in the 'heat' or 'cold' of the moment!!
As ours is currently being repaired and serviced I plan to have a short line added.
Our liferaft (as above) decided to abandon ship between New Caledonia and New Zealand. It inflated the right way up perfectly and was very re-assuring. Getting it back onboard was a different matter!! It involved reverse engine to slow us down, RIB lift block and tackles from the arch and a spinnaker halyard to get it aboard, and a sharp knife to deflate the two tubes and the arch. Only took the two of us a couple of hours!
Repair and service will be a little cheaper than a new one, but not a lot.
