Ian_Edwards
I have 4 LifePO4 batteries in parallel, max rating 150 amps each, max 600 amps total, nominal 5kW hr capacity
They struggled to run the bow thruster 5kW, 12volt, dropping below 11 volts under load of approaching 500amps.
The solution I've used is the fit a 75amp hr AGM in the bow thruster compartment on very short cables, less than 1m, and charge with a Victron 30amp B to B.
The AGM can handle the current for the short period of time the thruster is used.
