LEWMAR WINCHES
simba
25 Oct 2004
FITTED NEW CHROME LEWMAR 30 WINCHES ABOUT JULY LOT OF RUST ON BASE ALREADY ANYONE SEEN THIS BEFORE
sailorman
21 May 2003
Here or thertemp ashore
if the prob isnt comimg from the fixings, then you should talk to the supplier.
as for the nylon backing plates i would ( imho) used s/s or ali plates to spread the loads. i.e something that wont compress
simba
25 Oct 2004
looks like have to remove and check fixings and contact supplier stainless bolts came from compass thanks for all replies
cliff
15 Apr 2004
various
Just curious but what is "proper marine grade" stainless steel
I always understood the "304" grade was fine above the waterline with 316 being preferred for below the waterline (actually I prefer bronze or K500 monel but what do I know - I am only a metallurgist) I have never thought of either 304 or 316 as "proper marine grade" and I certainly would not recommend any of the 400 series as suitable for manufacture of fixings which would be subject to a marine environment.
Birdseye
9 Mar 2003
s e wales
316 is usually classed as marine grade. There are lots of grades of stailess that could be so classed, but since you can commonly only get fasteners in 304 or 316, then 316 is the marine grade one of the two.
<hr width=100% size=1>this post is a personal opinion, and you should not base your actions on it.
dickh
8 Feb 2002
Suffolk
SS Scrrews are commonly classified as A2(grade 304) or A4 (grade 316) A4 is better than A2 and only slightly more expensive. However will your average pkt of screws bought from your local swinderly know what it is? I don't think so!
<hr width=100% size=1>dickh
I'd rather be sailing... :) /forums/images/icons/smile.gif
AIDY
19 Jan 2004
Muckle Flugga
www.ybw.com
316 is food grade, so you can eat your dinner off it .
<hr width=100% size=1>/forums/images/icons/wink.gif <font color=blue> Regards Andy </font color=blue>
