Lenco Trim Tabs
Remmington
2 Nov 2006
Hampshire
HELP - Anyone know of any engineers in Hamble area who understand the system? A search only shows a couple of distributors. LED switch adjuster suddenly packed up and I have tried to trace cable back to the activator box and fuse, but I cant find either...the boat is a Bavaria 32 at Port Hamble /forums/images/graemlins/confused.gif
spannerman
30 Nov 2002
Had the same problem on the same boat, turned out to be a bad earth to the control panel, the power comes from the main power distibution board behind the panel on the starboard side of the hull in the mid cabin.
Remmington
2 Nov 2006
Hampshire
Thanks for that.....the earth could be the answer as I replaced the bow thruster switch panel which is in the vicinity of the trim pad.
