rigpigpaul
Hi All, what is the best time/ state of tide to leave Gibralter heading to Ayamonte in atlantic Spain. TIA
RPP
RPP
also very necessary > www.orcas.ptHi All, what is the best time/ state of tide to leave Gibralter heading to Ayamonte in atlantic Spain. TIA
RPP
You're more than welcome.. if you can get yourself into the straights by slack water, and with no Westerly's you should have a smooth passage. Do keep an eye out for those high speed hydrofoils though while crossing Algerciras Bay.. they are on you very quickly and can be quite unnerving..Saxonpirate, thanks for the advice. Looking at the tide tables low tide will be about 10.00 when I want to depart.
RPP
Best to be off Punta Canero around HW Gib +3.5 hours. Then you will get the most of the ebb against the standing current. Edit, stay close to Spain shore and watch out for very metal weather buoy east of Tarifa entrance.You will probably start to loose it around Trafalgar if you have made decent progress. Then you can take the very inshore route just off Trafalgar....100 to 150 metres. May need motor.Hi All, what is the best time/ state of tide to leave Gibralter heading to Ayamonte in atlantic Spain. TIA
RPP
11 Billion ???? Don,t be ridiculous, there are lots more than that.Welcome!
If you are taking the inshore route following the coast or orca avoidance, watch out for the tuna nets off Conil and as you get past Cadiz, about 11 billion unlit pot markers! The local fishing fleets often leave around dusk and they operate outside the pots. Can get a bit sporting.
