Leather sailing boots
The main thing is to never ever wear your decent boots when you are cleaning your deck with any form of deck cleaner as the chemicals in a lot of them react with the rubber on the soles and make them go hard - since realising this my current boots (must now be 6-7 years old) still have nice soft rubber soles.
Also obviously never store them in direct sunlight for the same reason.
And never wear them ashore!
Sea Boots live on the boat and are only used for sailing, everything else I have a £14 pair of wellingtons.
I'm not so sure about that, indoor sports trainers suffer the same problem with soles loosing their grip if only used indoors. Occasionally used on a rough surface abbraids the soles and they keep their grip, akin to giving them a rub over with emery paper.
IMO they are still the best, but the dropping of half sizes, and making them so they can't be re soled is pretty disappointing.
Thats the reason I won’t buy again. Why pay a premium for a cheapened product?
I didn’t notice a price drop when they binned their workers jobs in Ireland to offshore the production..
Indoor sports, wash your mouth out with beach ?
Last year I had my 20 year old Dubarry boots relined and re-soled in the factory for 50 Euro. Good for another 20.
Older Dubarrys can be re-soled, more modern ones can't. Anyone know when they changed the design?
Mine started to leak after about 4 years, sent them back, but they couldn't be repaired due to the changed design.
They offered me 10% discount off a new pair in lieu of being able to repair, but as repairability was a big incentive to buy them in the first place I declined. Doesn't seem like reasonable value any more.
The soles on my old Dubarry boots went hard - I think because they were left in a very dry air con room. This made them dangerous.
The soles on my new Dubarrys are a different material and feel like they will not go the same way ! I really like them and would buy them again.
I decided to give the Dubarry's a go but now that they have arrived I'm not convinced. The sole seems a bit hard / slippery and while I might be wrong at £250 I'm not going to take the risk, particularly now that you cannot replace the sole, so they are going back
Don’t blame you. Probably the biggest USP of Dubarry was their ability to be resolved. They still carry the price premium but no longer the feature.
As I suggested earlier, take a look at Quayside as I don’t think you’ll be disappointed.
Will do although Im going to attack my Musto's with a flap disc first to see if I can resurrect them! :-)
Personally I find the grip very good on them despite the sole being harder than you might expect.
Long ago had rubber style, but they started to perish after 2 years, crazing then cracking then leaking.
I've had Orca Bay boots - lasted 2 years then started leaking at sole / upper joints, and then sole cracked across and leaked. I glued inner tube on with contact adhesive and wear them in my workshop as they're comfortable, but no use in wet.
Next were Henri Lloyd. Worn 2 seasons and while treads and soles look OK, they too started leaking. Liberal application of "dubbin" type oil/grease tried, but didn't work. Now pondering what to try next!
The above experiences don't give a clear clue as to what to try, but perhaps the fisherman's seaboots idea is worth a try!
We have had Maindeck boots for the last 5 years. Not bad, but now leak like sieves. They aren't as warm as Dubarrys, but were quite a bit cheaper. They seem to have gone up in price in recent years relative to their competitors.
I'll never buy that type of boot again .
My Musto boots were so comfortable that you could sleep in them. But they almost put me over the side, sailing alone in the North Minch. I will never buy another pair of those either. None of the makes can now be re-soled. Rubber wellies is what I use.
I have a pair of Quayside with hard slippy soles after 8 or 9 years. They were very good, and have lasted well remaining waterproof. I took the risk and attacked them with the angle grinder, which improved the grip in 2019, but didn't get to use them in 2020. I will buy them again.
I think the broad consensus of the replies to this thread is that - as the soles of all modern leather or textile boots go hard after only a couple of years or so and none of them can be re-soled - the best bet each time is to simply buy another budget pair at half the price of the fancy brands! Or just wear wellies.
