nickstick
New Member
Hello sailors,
As I am new here you will hopefully make allowance for ignorance,BUT i am struggling to understand my Hurth 100 gearbox.It is like this.
The technical data says that the box is in forward drive when the input and output rotation run counter to each other.I can follow that
but having measured the gear multiplication manually I find that one input turn of 360 gives 120 degrees of out put in forward drive and
240 degrees in reverse.Is this as it should be?I had assumed that the forward gearing would be higher than reverse.I am wondering if
this is a modified box, or is it like that to overcome the inefficiency of reverse prop thrust so the o/p revs are higher in reverse to counteract this.
The reason for my worry is that I am putting a diesel engine/transmission in my 25 foot Broads cruiser and gathering
knowledge and parts as I go.So far I have a 25 hp Ruggerini diesel engine,a drive plate and a gearbox.The engine has no flywheel as yet
and everything beyond the gearbox is still to be purchased.I don't mind admitting I feel a bit at sea.Perhaps I am worrying unduly.
Any comment and guidance would be very much appreciated.
