Leaky Flubber
Stemar
12 Sep 2001
I have one of those "PVC disposable" inflatables - a 3-D tender, bought principally for its light weight. Since having to drag it across a concrete scrubbing grid, one of the side tubes has developed a slow leak - it's noticeably softer after 24 hrs and after a couple of days, it needs blowing up before I want to use it. I've tried to find the leak using dish soap and water, but no visible bubbles. Is there any better way to find a leak?
I've heard of goops similar to what passes for a spare wheel in a car I wouldn't be buying. Do they work, or are they just going to make my situation worse?
Thanks in advance
If it's only 'noticeably soft' after 24 hours, and doesn't actually need pumping up for a couple of days, it is a very tiny leak.
Try searching again with soapy water but this time with someone sitting on the tube (or some other significant weight on it), to increase the pressure and therefore the flow rate out of the leak, making it easier to find.
The 'goop' that you pour in to fix leaks - yes it can work - BUT you need to be careful of dinghys material and its glue used.
I had a Narwhal dinghy that developed a leak ... poured in the 'goop' .... next day sections of seam had 'unglued' .... took it to a repair shop and they determined that the 'goop' and original seam glues were incompatible.
But I have used 'goop' in my Avon ... its helped - but still suffers slow deflation ... its ancient and obviously porous. I have a tin of special paint that is supposed to not only colour the dinghy - but also help to seal porosity externally .. adding to any 'goop' internally.
You can slap soapy water all over my Avon and you will not find where ... but it still goes down !!
I think the sealant suggested was probably just liquid latex. I used latex to fix a rib with porous tubes and it worked fine, costs about a tenner a litre on amazon.
Do you have a link to the product you used as I have a rib with porous tubes that I need to fix
Get a rechargeable SUP pump. It will repressure your flabby flubber effortlessly in a few seconds.
I have one, that I got when I was recovering from open-heart surgery. I wouldn't be without it, but it does make one lazy!
We used to have inside storage that meant I had to deflate the dinghy to put it away. We now have a toast-rack storage where it stays inflated. Having fixed the leak, I went to put the dinghy to bed, and left it there while I ran the engine in a fresh water tank. Madame decided to be helpful by deflating the dinghy o_O I stopped her, but we've now got a rather soft tube, coincidentally, the one that used to leak. No problem, we've got the electric pump and a manual backup. Erm, they're on the boat. What do we use to get to the boat? The inflatable dinghy...
Buy a cheap one to keep in the car just in case it leaks or Madame decides to deflate it ......
