Hurley Iris
Dear readers,
I have a Dutch buld Hurley 700 (1980) which is rather similar to a 22.
It has the aluminum coloured mast and the single long windows on either side.
3 shrouds left and right, front and aft, I have a mast support.
Last weekend I was sailing some 32 nm across the IJsselmeer, and the boat was put to some stress.
10 to 15 knots of wind and waves over 150cm, some rain and cold.
This, to my surprise, soaked the cushions left and right (the front remained dry) and left about 2 pint of water in the bilge.
Inspection:
Cupboards are bonedry.
No water around the windows, under the masthead or the sealing.
The rubbing strakes are well sealed of but the wood is damp, soggy and soft in some places.
The rudder bearing is dry, on closer inspection the bilgepump valve failed so maybe some water has come in through the hole in the side, also some water from clothing, boots and rain got into the cabin so I am not to worried about the water in the bilge.
There was a wet cupboard (where the table is used as a door) , the chainstay runs through the deck and is attached to the hull. probably to a wooden block, laminated over. I removed the carpet so the laminate can dry.
This one I could reach and was wet and soaked the starboard cushion. The one behind the kitchen I could feel, it was damp and some water leaked on the cushion on that side too.
The others I cannot see nor check.
Status:
I dried the inside with a heater for some days and everything on board is stored ashore now.
I switched the heater off after some days, it is rather expensive to run and the boat is dry anyway.
Everything remains dry apart from some condensation and overall humidity as it is rather damp and cold and the boat is still in the water.
So I suspect it is due to sailing, water getting over and in due to the movemnet of the boat in the water.
But sailing is the whole point and the reason I have a Hurley is the ability to go when others must remain in the harbour.
So I suspect the chainplates leak and possibly the deck/hull seal has failed.
It was due for servicing anyway and the boat will be on the land at the end of march for some time until it is good as ever!
So dear reader, can you please help me to:
- Are my suspicions right?
- How to remove the interior cupboards / closets / kitchen so as to reach the chainplates mounts and inspect the deck/hull joint?
- Fix the chainplate issue: I want to remove the old Sikaflex, sand down the gelcoat around the chainplate (deckside) and laminate it over with epoxy, sand the plate some as to make sure the epoxy bonds, then apply 3M5200 and cover it with 3m5200. Both the epoxy and the 3M5200 have a little flex in them.
- The wooden blocks below deck I want to dry out and inject them with epoxy (if the wood is rotten will this suffice..?) then laminate them with a fresh coat of glass and epoxy.
- When the interior is emptied out I might as well fix the genoarails while I am at it en apply new kit. But how are they mounted to the deck? Screwed on or bolted?
Any help is greatly appreciated!
I know there is an Hurley Owners club but that is on Facebook and I do not want to join FB.
Iris
Inspection:
Status:
Iris
