ghostlymoron
My R and D couplings didn't look like that one..OK, that's an R&D coupling. You'll need to loosen the nuts which clamp the propshaft. You may need to twist a screwdriver in the slots to "encourage" the clamping surfaces to release slightly. There should be a key in the shaft, which you'll need to remove to slide a new seal over the shaft.
The new seal will come with a plastic insert, to protect the lip seals whilst the seal is slid over the shaft.
