Jamie Dundee
Looks like an ATF leak, unless it’s rusty water from the skin fitting.
When you remove the nuts on the coupling you will find that you also have to slaken the bolts. Even then you might not be able to pull the shaft out. Be prepared. Get two strips of hard steel just thin enough to put into the slots. Gauge plate is the type of steel you want, its high carbon steel and a lot harder than odinary mild steel which might distort and jam in the slots. Take out the bolts and put them back in the other way round so that tightening them against the hard steel strips very slightly springs the slot a little wider. The shaft should come out fairly easily now. Be careful not to lose the key if your particular coupling has one. Mine did and I would be a little wary of one that just relied on clamping pressure alone.
The Eliche Radice gland is an improvement on the Volvo and cheaper.
They do for a 1" shaft.True, but the stern tube diameters for imperial versions don't match the Volvo sizes.
McDonald’s straw was great two or 3 years ago but they are paper now and are likely to cause more problems by tearingIt won't just let go on you, it'll just keep dripping more and more as time goes on.
If you get some thick silicone grease and push it into the seal (with a McDonalds straw works well), then that will give it a bit more life.
They are easy to change, but replace it with the Radice version, as it has a grease point and also a breather, so you don't have to burp the air out of it when it goes in the water (they're a bit cheaper too).
Sorry. Just seen I was beaten to this comment.McDonald’s straw was great two or 3 years ago but they are paper now and are likely to cause more problems by tearing
I saw that coming and laid in a stock of plastic straws. A bit overkill, unless I'm still sailing at 200 because I've re-used the same one now for about 4 years. I just cut the flattened end off and refill but will probably need another straw in about 5 years.McDonald’s straw was great two or 3 years ago but they are paper now and are likely to cause more problems by tearing
Interestingly I've just been reading that these seals are supposed to be greased once a year. Despite the company that originally fitted it doing a fair bit of work ashore 2 years ago (incl. replacing cutlass bearing) they didn't mention the stern gland. I'm presuming this is something I should have been doing every time I've hauled out...
I said about 20mm in post #10 but think that's actually too far and 15mm would be fine. My notes are on the boat in Greece and I've obviously skipped 2 launches now. Last time I greased it would be early 2019. I think that one seal was approx. 2.5mm from the end and the next was about half that distance (i.e. 1.25mm). That would make the mid-point about 1.9mm and makes my first guess of 2mm and second estimate of 1.5mm sound reasonable (my boat has a 30mm diam. shaft).How far do you need to push the straw in to grease properly?
If you look at the section of the Volvo seal on my website you will see that the grease only needs to go in a very short distance to pass the lips. Stern glandsHow far do you need to push the straw in to grease properly?
Probably obtainable in a poundshop or similar, in sufficient quantity to outlast OP's ownership of the boat.McDonald’s straw was great two or 3 years ago but they are paper now and are likely to cause more problems by tearing
