leaking transducer
aidancoughlan
24 Jun 2002
co.Wicklow, Ireland
yep, sikaflex - just installed two new Navman transducers with lots of sikaflex, and its drizabone.
Did you use any bedding compound? It definitely needs some compound - sikaflex recommended in the navman blurb.
best of luck.
fireball
15 Nov 2004
Is it a retractable thru hull fitting? Ie you've just swapped the actual transducer rather than the fitting it attaches to? If so it sounds like there is a rubber seal that would need replacing ...
If not then - I guess sikaflex is your answer ...
RivalRedwing
9 Nov 2004
Rochester, UK, boat in SYH
If it is a retractable fitting did you put some silicone grease on the o-rings before installation? - essential for a leak free, easily removable transducer. Don not use sikaflex on the o-rings if you ever want to remove the retractable bit in the future (and you will because it always cruds up with something during the season)
Most transducers have an o-ring fitted just above the impellor part so that it seals in the tube.
It would seem strange if there is no o-ring or seal anywhere if its retractable ....
