BarryT
Problem – lots of exhaust blowing back up between 1 injector and the copper sleeve it sits in inside the cylinder head.. Having taken the injector out and found no obvious further problems, I’m now advised that the sleeves do wear and have to be replaced. So head has to come off, and sleeve professionally replaced.
Any ideas for cheap alternatives as before starting the work I can already see the costs mounting up.
• Might as well do all 3 sleeves
• Get the injectors serviced whilst out.
• Check valves etc & regrind if needed (bound to be) whilst head is off
• New gaskets
• Labour cost
• All on an old engine, so ought to check the gearbox spline whilst the engine is out of action
And before I know it, that’s over a grand. Now given previous comments on Volvo 2003 series if I’m spending that money just to maintain the engine's current condition I ought to consider a whole new engine ? And all because 50p of copper tube needs replacing.
As far as I can see, the seal relies on a tight fit of the injector in the sleeve and it resting on the base of the sleeve around a central hole the injector pokes through, so what’s wrong with just putting in a little gasket sealant ?
Any suggestions please
Barry
• New gaskets
• Labour cost
Barry
