colhel
I've just fitted, but yet to try, lazy Jacks. I'd be interested to hear of problems anyone had and how you resolved them.
Baton entanglement when raising the mainsail.
Only problem is that you need to face the wind to raise the main; which can be a pain , but there are more advantages.
Lodesman77;4355104 Fit them so you can slacken them and take them forward for hoisting said:If you do that the main falls of the boom and that can cause other problems.
Not a problem for boats without lazyjacks, surely!
Anyway, Im getting increasingly fed up with the ones Ive got and they are very soon for the chop. I say that every week but they are seriously, seriously gonna go. Soon.
That is a usual problem.
Need to make sure the boom is dead in line with the wind and the person on the halyard is watching until the battens are clear.
Ianfr of the forum has set up a system to pull the lazy jacks to the mast before hoisting.
Seems good but leaves a lot of rope around
Fit them so you can slacken them and take them forward for hoisting, and re-tension them for lowering.
If you have the main flaked on the boom and undo the sail ties then push the boom out over the water and the main falls in the water then it can be a problem.
Didn't you try them when you fitted them?
They catch the battens if fixed.
