Layering-up matting 12:1 Long sheet first/inside or last/outside?
Robert Wilson
23 May 2012
Second Coast, Ross-shire, overlooking Gruinard Bay
Approx 170mm length/14mm thick 12:1 layering down my skeg and into rudder-shoe.
Should I place the 170mm layer on the skeg first or the shorter lengths with the 170mm covering all the other increasing lengths ??
I shall fair-off with filler (of some sort)
I have plenty of height so the 170mm layer could easily be extended to 250 - 300mm, with subsequent layers increasing in length too.
The rudder shoe will be bolted through the layering and through a 8mm s/s plate embedded within the skeg..
For those of you who followed my "What should I expect now" thread last year, I am at last about to repair the skeg/shoe cock-up that I made when removing the rudder. :eek::eek::eek:
All advice gratefully received.
sailorman
21 May 2003
Here or thertemp ashore
biggest last
make a pattern of the area, draw "annular rings" following the shape, place pattern on the matt & cut the largest then the nxt ring until done.
lay -upthe smallest first & the largest last, you then seal in all the fibre ends & end up with correct profile
VicS
13 Jul 2002
Biggest first.
Then you end up with a series of stepped edges that just need fairing off.
If you start with the smallest and work towards the biggest you end you with a series or resin filled voids around the edge of each layer.
You are using epoxy and biaxial cloth presumably, not polyester and CSM
PlankWalker
2 Feb 2010
South UK
I would start with the second biggest, work my way in to the smallest, then work my way out again to the biggest, working in and then out gives you a bigger overlap on each piece.
Bobc
20 Jan 2011
biggest last
What he said.
Davegriff
19 Jun 2010
SoF
Probably doesn't make much difference, but I've always layered from smallest to biggest on the theory that if a layer doesn't "take" for any reason, it'll be held by the next up, thus less chance of the completed patch delaminating in one chunk, and it only has one "edge"! Probably nonsense, but I've never had a patch delaminate.
VicS
13 Jul 2002
biggest last
What he said.
No Its wrong largest first ..... read the West system user guides etc
Gentlemen!
I await a consensus of opinion !!!
But thank you for your prompt responses, all of which have merit.
I shall be purchasing bi-axial cloth and whatever East Coast Fibreglass Supplies recommend; presumably epoxy
See the West System user guides which are available in the ECF website, esp the one on "Fibreglass boat repair and maintenance".
Do it the way West advise. Ignore the people who have not read the guides
https://www.ecfibreglasssupplies.co.uk/topic/westsystemuserguides
See also these guides to choosing and using resins and the various fillers.
http://www.westsysteminternational....g-west-system-hardeners-fillers-and-additives
http://www.westsysteminternational....additives-to-west-system-resin-hardener-mixes
PuffTheMagicDragon
16 May 2001
It doesn't really make much difference.
You will need to fair the layers when approaching the finished size. When I did a similar operation I used a flap-disk on an angle grinder to smarten up the shape before I put on the last two or three layers. This ensures that the fibres of the last layers are not disturbed (cut) as they would be when you apply a grinder to them. It also reduces the amount of epoxy fairing putty that you will apply before the final coats of epoxy.
Incidentally, for the actual re-build I used alternate layers of woven rovings and CSM with 'normal' polyester resin but epoxy for the final coats over the fairing putty.
The same method was used for the aft edge of the keel where there used to be a trim-tab.
Motor_Sailor
21 Jan 2017
Norfolk
Oh yes it does (and not in a pantomime way).
And the reason is apparent when you come to sanding and fairing. Now if you've used simple CSM it doesn't make any difference, but if you've gone to the trouble of using biax, you want the fibres to be continuous along the load path. The longest ones do the most work and if they are the surface layer, there's a chance they will be sanded through and either cut or degradated during the finishing process.
The rule with composites is always "bury your load carrying layers and fair the choss on the top".
sailor211
17 Oct 2007
Gosport : Boat Soon to be Gosport
This makes sense to be . So enough filler and faring material over the biax so no fibres are sanded.
PuffTheMagicDragon
16 May 2001
You should never have woven rovings as the last outer layer and I don't think that I suggested doing so.
I think that we're saying the same thing in a different manner.
