Parmesan
Over the winter, I replaced the hoses on my (manual) Lavac and serviced the pump with the service kit. I also replaced the L shaped spigot on the back of the bowl.
On going back in the water, however, the heads don't work. I can hear air bubbles being pumped out below the boat, but fresh water isn't being sucked into the bowl.
I have covered the vent hole (temporarily) with amalgamating tape (in case it was too big) but this didn't fix it. Also if I remove the hose from the spigot, put my hand over and pump, I don't feel a suction. The seat lid appears to be sitting correctly but I'll recheck that. Hose clips appear tight.
I am assuming it is an air leak (leaking in), but there isn't any obvious source. I used the thick white rubber sanitation hose so would be a bit surprised if it had a hole all the way through.
Are there any other suggestions for things to investigate or try to narrow down the cause? Also, could there be any problem with the pump (misassembly, over or undertightening) that would cause this problem but still allow it to pump air out?
