TSB240
It helps a lot if the rope is wet...
(as it will be after the first failed attempt)
Or weighted!
If I am praying for a speedy berthing then I always have the two ends inboard with a big loop and you cast the lines out like a pizza and it gets the job done. Lassoing with a bowline is doomed to fail many times due to the weight of the line. If you are thinking about "Rawhide" then that is what you need, stiff line that holds it's shape in air and pulls tight on pressure.
Anyway forget the bowline keep the two ends on board and remember "making the pizza".
I have a snap hook on a spring on my own boat but still practise lassoing with SWMBO quite often.
Exactly. If a technique works, and does no harm, I can't see any valid reason to object to it.Why do people persist on thinking that there is some sort of 'RYA way' of doing things?
There is good seamanship and poor seamanship. All the people saying that it's a rubbish technique or 'it doesn't work' are missing the point. IMHO. It's another tool in the box that is sometimes very useful.
It's NEVER been suggested it's anything other than a quick way to attach yourself to the buoy while you sort out a proper mooring line to the shackle or whatever.
What's this 'proper' way people are talking about? There are lots of ways to pick up a mooring. The proper way is any way that works that is safe and seamanlike.
When I'm examining people, that's all I'm interested in...
I don't disagree..however a quick thing to get the boat stable often turns into a several hour thing....leading to a failure somewhere. People get lazy so if a shortcut or quick thing is taught as the leading way to do it then it soon becomes the norm.
A lasso is easy...simple...quick..almost anybody can do it with some success...meaning that people will use it over other methods that lead to an instant stable secure position.
This is the reason why i don't like such "quick temporary" methods
Bought one of these this year - blooming brilliant ....
http://www.hookandmoor.com/works
No lasooing needed
While most of us wouldn't argue for the technique to be banned, many of us, I suspect, have misgivings about lassooing being taught, under the auspices of the RYA, as a normal way to pick up a mooring. In the kind of AWB that is usually used for instruction, manoeuvring under power, or even under sail, should not be difficult, and we would prefer that trainees spent their time learning sufficiently good boat control to allow for normal mooring techniques, of which I favour the alongside method.That is all very well (and I have something similar), but you need to have something to hook. As has been pointed out earlier (eg by flaming in #5), sometimes there just isn't anything easy to attach to as you approach a buoy. So the method does have its uses. Some of the time.
I wrote:But the point that some of us would like to make is that if the buoy is an inflatable then it can do harm.
If you have a situation whereby you return to your mooring & find £300 worth of mooring missing because your buoy had sunk, having been split, then I think that you would have the hump as well.
I do not mind people using my mooring, provided they vacate it when i return ( item for another rant) & provided it is left in its original serviceable state & not damaged
Is that unreasonable??
I wrote:
"Like most things it's something that needs using with a bit of common sense."
Which bit of this sentence are you having difficulty understanding?
Here's a photo.I am far from clear in my own mind how to identify an "inflatable" buoy. Clearly, the kind of buoys set out for visitors in places such as Salcombe or Yarmouth are robust enough for most purposes, but often one finds that one is attaching to a mooring belonging or rented by a resident boat. These are normally vaguely spherical and roughly two foot across, so how am I to know if it is inflated or not?
With that much tide i would suggest deploy a 100kg Fisherman anchor :encouragement:Being a complete novice, what method should I be using to pick up a mooring such as in this photo: http://www.internationalyachtsupplies.com/mooring-buoys/mooring_buoys.jpg
In the scenario that we are stopping for lunch?
We had some own boat instruction, and the instructor had us lasso a mooring by motoring towards the bouy against the tide and using the tide to stop as we arrived at the bouy. One end of the warp was attached to a cleat and the other was loose until the bouy was lasso'ed.
For moorings with a pick up bouy I would hook the pickup, but it is the ones without the pickup, I am now unsure about!
