Neeves
I took some advice here on YBW PBO and bought some high speed rotary rasps to 'machine' higher tensile steel and aluminium. They have a 6mm shaft, which I thought at the time I ordered them - a bit small. They are actually not that much different to some wood routers I used to have in the UK and are the same shaft size. The ones I bought are fine, for grinding small areas - they are really just a size up from a Dremel
I am sure these devices come in bigger sizes (with bigger heads). It the larger heads I'm looking for. I'm making prototype devices for a yacht not a model airplane.
I might be using the wrong keywords -but I'm not coming up with anything sensible.
Any suggestions.
With thanks.
Jonathan
Any suggestions.
With thanks.
Jonathan
