Neeves
Is this it or an approximation thereof?
Can you drill and tap? Two pieces of steel sandwiched and screwed together, drill your 26.5mm hole down the join line from opposite ends. Can you soft solder? Same process, but with solder instead of a bolted joint. Even epoxy would do the job, then heat to release afterward.
Pretty exact
I confess I did not see why it was difficult to understand - my use of English obviously needs some polish
I did not think of 2 pieces of steel clamped together. I have plenty of clamps, including the drill clamp.
Jonathan
I cannot see why it will not work - I'll give it a try. Good idea. Lateral thinking is still alive and kicking.
