I wouldn't use one, try getting that pin out on a dark windy night when you need more scope or are dragging. A chain hook is much better.
Better still, a rope stopper with a hook on the end Far less likely to need to cut it, but you still have the option. I just describer my snubber.
Had a chain hook 'jump' ... not a great lover of them ... basic rope for me if needed.
Rolling hitch ?
I have one snubber with that shackle (among several different ones), I used a steel thimble with 12strand spliced rope, by memory a 16mm fits fine. A bit of leverage is needed to twist open a 16mm thimble to insert the Kong and then closing it back.How would you attach this to a mooring strop? Shackle or thimble?
A chain hook will not come off the chain provided there is sufficient loop of chain that it is always slack at the extremity of snubber elasticity. I have used chain hooks, simply tied to the snubber with a bowline, for something like 15 years, in winds to around 50 knots. Not once has one come off the chain.For my snubber I use one of these, great bits of kit. Yes you do need the Leatherman (or pliers) to undo it but that is easy. I use a hook and a shorter snubber for benign weather or overnight stop. The advantages of these is they are secure. A hook will un hook and a knot will slip or refuse to un knot. I actually have a few snubbers with these Kongs on ordered from Jimmy Green. I have some secured on a rope splice and some on a stainless steel thimble.
Last season alone I saw two snubbers attached with rolling hitches that had to be cut off. Several others previously. It's not the loss of rope that's the problem, it's the time it takes in emergency.
None of the above!That also brings me to a point ... if you are going to cut a line that's under tension - where do you cut ? 1. at the point it goes over side of boat ? 2. Half way back to cleat ? Or 3. right back at cleat / fast point
None of the above!
Take in the chain until you have removed the tension on the snubber then you can choose where to cut if it is necessary, but you will probably be able to reel in more chain and undo the snubber.
I've never been in a situation where I couldn't untension a snubber. Even without a windlass, a rolling hitch onto the chain, rope back to sheet winch and tension. If necessary, repeat with second line to other sheet winch and keep alternating until I got to the snubber / chain connection.That's IF you can .. my point was when you cannot
Your comment cannot apply to a yacht with a windlass. All of the rope must be removed if the chain is going to be returned to the locker. As said, it is difficult to imagine a circumstance in which the tension in the snubber cannot be released by hauling in the chain. My hook always falls off at this stage.That's IF you can .. my point was when you cannot ... and if a line is under tension - the knife has far better chance of cutting quick than a slack line ... Illustrating the line has a recoil or as we call it on ship - Snap Back ... which can seriously injure.
Of course if you can get chain in to undo / remove snubber ... but imagine when you cannot ..
Absolutely, just like getting the hook up when the windlass is bust, leapfrog lines from the halyard winches on the mast. Spare chainhook speeds that up, been there, solo, engineless..I've never been in a situation where I couldn't untension a snubber. Even without a windlass, a rolling hitch onto the chain, rope back to sheet winch and tension. If necessary, repeat with second line to other sheet winch and keep alternating until I got to the snubber / chain connection.
