wooslehunter
Someone in the past has tried not too well to bodge the keel seating compound but there is little evidence of any movement so I won't be re-seating this year. The sealer placed over the joint has started to come away though so needs replacing.
Hence the plan is to removed the sealer put over the join, clean back as far as I need to, to remove any loose rust, sealer etc. and then re-seal/paint.
The question is what to paint / seal with. I may be taking the keel back to bare metal at the join so need to know what to coat that with.
Any suggestions on best plan & what to use?
