Becky
We are planning to alter the piping in the bilge in our Moody 37, which entails moving the strum box of the hand bilge pump. When I unscrewed the retaining screws, one was just into the hull, the other was down its full length (approx 2.5cm) and there was a weep of water coming out of the hole when I took it out. So, to me there is a leak, possibly not directly from the sea below the boat, but there is a keel bolt a few cms away, from which a leak may have come.I don't think the screw was through to the keel, surely Mr Moody would have made the bottom thicker at this point?
So this poses the question where does the water come from? And more importantly, is it between the keel and the hull, rotting the keel bolts, which HWMBO assures me are mild steel. I would now like the boat out of the water and all the keel bolts checked and /or replaced. Which wouldn't be an easy thing at all, especially as we have just had a full osmosis treatment (3months ago).
So, what would the Forumites suggest is our best plan, bearing in mind we are planning to go long-distance cruising?
