Kamd44 edc start problem
jukohaka
17 Feb 2014
Hi,
I’ve got 2 kamd44 and cannot get the SB to start.
- On pushing active station, diagnosis light occasionally flashes once and neutral / active station lights don’t light up as usual.
- Most of the time the diagnosis light doesn’t flash either when pressing active station.
- This happens on both stations in the boat symmetrically.
- When pressing diagnosis for error codes, I get 1.1
Any help would be appreciated ?
J
1.1 means no errors
I had a similar issue couldn’t get neutral light or active station red light turned out to be a loose wire in the multi plug
No it’s was the one behind the control panel, but worth checking the one going to black box can get corroded
Hi,
J
Do you have a fire system installed ?
remove the stop solenoid wire and try and start it .
