petem
We've had a curious issue ever since we had the boat and looking back at the boat's service docs the previous owner had the same issue. He even went as far as having the cooling system pressure tested but never found the root cause.
Basically, the port engine doesn't like to be filled with coolant more than about 2cm above the bottom of the expansion tank. If we fill it more than this then it ends up in the bilges.
Col (formerly of this parish) was adamant that the expansion tank is too small on this engine and that 'they all do that'. His view is that the engine contains many litres of coolant so being short of some in the expansion tank is inconsequential.
Needless to say, the engine doesn't overheat (temps are the same for both engines).
Somebody else has said that the expansion tank cap could be defective but that doesn't feel like the cause to me.
Does anyone with KAD44's get the same issue? If it's relevant, the calorifier is on the port side.
