Sishoe
This is really starting to do my head in.
A few weeks back I posted a thread about my starboard engine mysteriously engaging forward when in neutral.
Since then I've had trouble getting a SB neutral light when trying to start the engines, had the SB engine disengage drive and drop to 1K rev when crashing down off a wave and the same engine not disengaging drive when the lever is returned to neutral.
When the last of the above 3 incidents occurs, I've found that the neutral point has drifted to the reverse point and reverse is in the reverse throttle zone.
We initially checked wiring and plugs under dash and on engine and everything seems fine. Then the potentiometer was changed in the SB control. But still the same intermittent fault.
I've lost count of how many times I have now re-calerbrated the control.
Time to get VP engineer involved who looked at the boat this morning, but didn't really find anything. He did recommended some kind of module that is fitted to the wiring coming off the helm control that apparently cleans up the signalling and stops any power spikes.
I can't see it working, anyone else got any ideas what could be causing it?
One thing, it seems to be more of a problem if I've left the chargers off, although the batteries (which are only six months old) are still reading 12+ volts before starting the engines. Also the auto shift problem has occurred 3 times, all after extended running in gear at tick over or on the pontoon with engines running.
I'm running out of ideas and the summer is surely just about to start!
