Dazzajohm
N/A
I admire whoever has taken the time to make that gasket but sadly after fitting hundreds on and off over the years I doubt as it’s cork it will seal .
I’d observe that because the rubber gasket sits in a groove in the cover and it’s a lot thinner than the cork gasket the gasket will be pushed out of alignment when it’s tightend down .
The reason I’m saying this is because if you look at the cover where the bolts pass through it there is a machined stop so that when you tighten down the cover the stop makes contact with the head face so that the gasket is crushed at the correct pressure to seal , that way you can’t over tighten the bolts and push the gasket out .
The cork gasket looks too thick , it remind me of the Ford Dorset Dover gasket that has such a span between the bolts it sometime pushes itself out or inwards then you loose the seal.
In all the years I’ve been doing this I have never bought the stupidly expensive glue from VP , I’ve used black gasket maker from a car factors , wynns is a good make about £9 a tube.
One observation from Andy 59 is the fact the cover may not pull down to seal around the injectors plus to will sit too tall to enable fitting of the injector leak off rail.
When I do this job I always remove as much of the engine as possible to enable a straight drop vertically down and evenly when fitting so that the glue spreads evenly , take off the turbo inlet pipe and the spill rail pipe that goes under the black box to the top of the inejector pump, that gives you a clear drop, taking off the engine lift brackets as well can help especially on the terrible Prestige 32 and 36 boats .
Of course I wish you well in this attempt to sort your leaks and am happy to be proved wrong.
Thanks for the insight Paul.
I guess after 3 failed attempts by two different mechanics to seal it I thought it worth giving something else a try.
As I mentioned in a previous post, I dont get the cover & gasket until Sunday but I believe the gasket is only 4.5mm so should leave plenty of room for it to pull down and seal around the injectors (fingers crossed).
I think the plan is that when the cover is fitted to use the gasket along with some Wynns (previously I believe they used the VP stuff).
Should get the boat finished off next week and hopefully back in the following week so I'll update this post either way once I know whether it's worked or not.
