CraigC
Hi, any suggestions would be welcome
2 x KAD 44 on DPE, 1000hrs
In the last year port boost slowly dropping. Two new turbos replaced 2 yrs ago and now at cruising 3200 rpm about 5 psi difference, also 10% less fuel.
My understanding is the fuel computer EDC will allow more fuel if enough boost being created.
So far the following has been completed.
Normal yearly full service, filters etc. checked for air charge leaks in pipes and aftercooler box, no leaks of water or air.
Mixer on port engine removed to allow visual inspection of exhaust side of turbo and all good.
1000hr top end service on both engines, injectors, valves and compression tests, all good (injectors nozzles replaced etc)
Swapped fuel computer with each engine and fault did not move, so not the computer.
Air pressure sensor on manifold my last option that I can think of which I will test this weekend, sensors looked ok when swapping over.
Has anyone had an issue like this and have suggestions of what to consider ?
Regards.
Regards.
