simonfraser
1999 vintage, the blocks have sat on top of the KAD shaking about with the wires relatively unsupported once out of the block
one green wire, bottom left on left block, insulation busted, copper strands popping out
and the connectors are cracked and split, looks as if some one has been here b4 me
i rearranged the support as best as i could, but now get error lights, temp / oil / battery on the dash and it obviously won't start
could have left it alone, but that was a problem waiting to happen, at least it did not happen on the water
so, what to do, i am experienced at soldering / heat shrink and recon i can support the finished article way better than the spidery mess there is at the moment
or fit another plug / socket setup, the wires into the bottom blocks look particularly suspect
is the bottom part / cable replaceable ?
suggestions please !
