aquatom
Just remove an exhaust elbow and have a look at the blade gap. As stated in your first post your problem sounds exactly like worn turbos but dosnt explain the sudden loss of power. If both turbos had seized which is unlikely but possible then it would explain the sudden loss of power you had. Again removing the exhaust elbow would soon tell you. If you do need to remove the turbos we usually change a pair of turbos in about 10 hours. If its your first time you can double that!
As the turbos normally wear slowly people don't notice the power dropping off until the supercharger starts cycling in and out. Then the turbos get replaced and the boat is transformed.
It's a 10 min job to remove the elbow and have a look.
