Kad 32 Raw water pump
According to this page Keypart your pump is identical to my one on my tamd41pa which I refurbished last year. Here is the dimentioned drawing of my pump raw water pump drawing.pdf
Www.solocoastalsailing.co.uk
Thank you for such a prompt and useful reply, certainly is identical, showing the slot depth @ 11mm and just slightly above the mounting face of the pump, I think I will set it at 12mm and if I don’t feel any resistance when I offer it up I will refit at that,
Much appreciated Bill.
Do not, under any circumstances, allow that water pump shaft to protrude any further than it should do onto the fuel pump drive, applying pressure to the fuel pump.
Please don't ask me how I know this to be true.
I am well aware of that, which is why I asked the question in the first place... thank you.
... and that was after I gave the pump to a VP dealer to sort out the seals :oops:
How unfortunate, I hope you presented your VP Dealer with a Bill for the subsequent repairs, if you asked Volvo to replace the seals they would have removed the shaft for sure, therefore the responsibility for correctly refitting it is down to them...
