kashurst
Its started already, had boat lifted for the usuals, however starboard engine wouldn't start. It was OK back in February. The edc control wouldn't "select" the engine (this is third hand, I am still in UK, boat in Spain 'so may not be exact sorry).
It sounds just like a problem I had back in November. One of the two fuses blew. NOT the compressor fuse! the other one that supplies everything else. At the time we replaced the fuse and everything was OK until 3 days ago.
I have been studying the engine wiring diagram and its mostly sensors which I wouldn't expect to blow a fuse, just give incorrect readings. However there are three solenoids described:
Actuator** - apparently its on the fuel injection pump - what is it?
Solenoid Alpha** - on the injection pump - what is it?
Stop solenoid - I am guessing its on the injection pump - where is it?
Are these just 12v activated solenoids or something electronic? If so can I test them with a 12v supply to check they click in and out. My engines only have 140 hours after 14 years so I suspect a bit of corrosion/sticking in one of these solenoids is taking out the fuse - which is only 7.5A. However its pretty hard to tell as this one fuse powers a lot of bits and pieces.
Any other suggestions welcome. Thanks
