Daydream believer
That is odd, because if one wants to release a piece of steel that has been glued on to onto a plate with CA whist turned in a lathe, (a common procedure) one just has to warm it a bit. It then drops off dead easy.If you really want to make sure they can never pull apart without soldering ... drop of CA into heat shrink tube ends immediately before shrinking.
So I would expect the act of heat shrinking a CA glued item to just kill the CA. That being said the "dead" residue probably helps hold the parts together
