hullabaloo
I will give it a go. thanks
ps I may be back for more of you local knowledge.
Define "require".It’s true you can have a hull which require 0 tab to plane , and 0 tab throughout planning speeds .
Only tab needed down in a head sea to get more parting from the front finer sections and minus tab ,ie up from the horizontal in a following sea ( going fast ) to get the bow up to minimise broaching .
Other than that 0 all the time .
Define "require".
If you mean that it's possible to build a boat whose AoA remains constant through her whole P speed range without using tabs, we can debate till the hell freezes over about whether theoretically such possibility exist. But factual evidence shows that no boat afloat behave like that. None, nought, nada, nothing, nil, zero.
Yours included, of course: as you know, I've never been onboard her, but I'm happy to bet a case of your preferred champagne that she's no exception.
Bigplumbs is 100% correct, though: we are way o/t with this, so I'll refrain from commenting in more details on the drawings you posted.
Happy to contribute as much as I can if you wish to start a specific thread, though. :encouragement:
Intriguing offer, but I must decline it 'cause my boat is still on the hard.Instead is it possible I come aboard your boat armed with a cordless drill and a few wine bottle corks .
Allow me to drill two holes in the mid lines at the dock through the hull .
You don't need to drill a hole. Just remove hose from a seacock in roughly the right place. One without a scoop. Or if you have fw flusher points on your seacocks (qv,) just open those. I'll do exactly that and report back on this in a few weeks
. I have an airco inlet sea cock with a flushing point just in front of my engine room door, which I think is the correct location Porto (?)
Pardon? I can't for the life of me understand what relevant conclusions you can draw from a video showing a speedboat maneuvering at D speed.Alternatively see the rear / stern suction effect every day more so on low aspect ratio boats ( long n narrow beam )
Watch this slow speed manoeuvre especially as it turns early on - notice the stern sinking
https://m.youtube.com/watch?v=aHnvI5bQbEQ
Wider beamed boats with greater aspect ratios stern sink less , they create less proportion of suction , more lift .
Well, obviously we must, yet again, agree to disagree - completely!Ultra Speed and seaworthiness are antagonistic
