MartyM
Hi everybody
I have a Nanni Diesel 4.390 tdi which has just started to play-up, firstly it won’t stop when I turn ignition key to off, it takes many attempts switching from off back to run until eventually (and for no apparent reason) it finally stops, also the voltage indicator started showing high charge (just under 16 volts) whilst engine was running. Hopefully looking for some advise/suggestions for what may be the problem or problems
. Unfortunately, there doesn’t seem to be a manual cut-off facility with this particular engine. Any guidance would gratefully appreciated.
