MikeBz
Jabsco pump stopped pumping water in yesterday. Pumping out working fine. Checked the seacock was open and no blockage. I had a service kit at home so took the pump home and dismantled it. One of the flap valves (is that the correct term?) in the top valve gasket had fallen apart, so I cleaned everything up, fitted the service kit & reassembled following instructions with the kit and various YouTube videos. Refitted it to the boat today and it still doesn’t pump in, but worse when you try to pump in water dribbles and squirts out from the interface between the valve cover and the pump cylinder (part names from Jabsco’s own pare parts list). Took it apart and double-checked everything, reassembled - same problem.
The only thing I could think of is that the top valve gasket is too thin and not making a seal, but checked it against the old one and it’s no different. So I’m stumped. Looks like I’ll just buy a whole new pump but I’d like to know why this is happening.
