Skylark
I'm still having fresh water flow problems since replacing the failed pump regulator valve. It seems impossible for the man-in-the-street to contact Jabsco directly but the parts supplier has been helpful and Vyv has been super-helpful by PMs but I'm running out of ideas, hence looking for a fresh pair of eyes.
My Beneteau has a Jabsco fresh water system and the Par Max 4 pump is fitted with a 30 psi cut off valve. It is not possibly to get a replacement cut off valve as these are dedicated to the Beneteau system (seems a bizzare response) so I was supplied with a 25 psi valve as a replacement. The lower pressure valve for this pump is 10 psi and the accumulator should be set at 2-3 psi lower than this, according to the spec and instructions.
With the accumulator set to 7-8 psi, per the spec, with any tap fully open, the pump runs for approx 1 second, off approx 2 seconds. But, big but, by the time that the pump cuts in, the flow out of the tap is barely more than a dribble. If I completely vent the accumulator, the pump runs for about 1/2 second, then off for 1/2 second, repeat. The flow is no more than a dribble before the pump kicks in again.
I've video'd this and sent it to the (well known and respected) parts supplier. In turn, they have sent it to Jabsco who have now said "set the accumulator to 13 psi. This contradicts their spec sheet for the 25 psi valve but I'll try it when I next visit the boat.
Does anyone with fresh eyes recognise these symptoms and know how to restore proper (prior to the valve failing) pressure and flow?
Many thanks.
Many thanks.
