Jabsco not priming
Kevin davis
28 May 2023
Hi all.i have jabsco raw water pump that won't prime.i have checked hoses and clips right through to pump and found no issues.ihave water making it's own way to pump inlet.i can get it to work perfectly if I disconnect outlet pipe and suck it then reconnect to heat exchanger problem comes when I turn engine off.when I start her up again I have to repeat sucking process.i have found a very slight drip at back of pump but not enough to cause system to drain in such a short space of time.any help appreciated thanks guys
Kevin davis
28 May 2023
ok thanks for your speedy reply.i have a spare pump but driveshaft to short.il take plate off that 1and try that today as they are the same pump.with different length driveshaft.i will let you know how I get on.thanks again
fisherman
2 Dec 2005
Far S. Cornwall
the pump depends on the seal between impeller and back and face plates. The back plate is often forgotten.
Plum
6 Jun 2001
UK East Coast
It only takes a very small air leak on the suction side to stop the pump from priming without assistance. In my experience that was a result of an imperfect seal on the lid of the water strainer.
Plum
6 Jun 2001
UK East Coast
With the pump faceplate off put a straightedge across the pump to check the impeller is flush. Also check nobody has replaced the very thin paper gasket (assuming you don't have an o ring) with a thicker one trying to solve a leak.
Kevin davis
28 May 2023
Something else for me to check on today.thank you m8.you could well be right as there is no seal on strainer but I will make 1 out of rubber mat I have down boat.i thought it just had to be tight enough to stop leaks.
Kevin davis
28 May 2023
Ok will do today
john_morris_uk
3 Jul 2002
At sea somewhere.
Our strainer(s) have an ‘O’ ring seal in them. I usually put a very light coat of Vaseline on them to stop them sticking.
vyv_cox
16 May 2001
France, sailing Aegean Sea.
coxeng.co.uk
Worn shaft seals can also introduce air into the pump. I had a similar problem, water drained out of the suction line after long periods of sailing, after which the pump would not prime. Shortly afterwards the seals began leaking. Replacing them solved both problems.
Kevin davis
28 May 2023
PetiteFleur
29 Feb 2008
Suffolk
I found that a good smear of vaseline on the thread of the strainer cap fixed all my problems with not priming. I also made a wooden 'lever' to tighten the lid(and loosen it !) Works well.
Kevin davis
28 May 2023
Thanks mate I have noticed that the seal at back of pump was not sat in its seat so put that back in might be the problem but won't find out as I've now found a leak on my sump so been stripping everything out ready to lift engine to change gasket.such fun.thanks I'll get sump done then jump back to pump
Kevin davis
28 May 2023
One more question guys I've looked at faceplate for wear and there is some.would it work if I just turn it around the other way so the outside of plate is on inside just to prove a point?
vyv_cox
16 May 2001
coxeng.co.uk
Yes you can do that provided there are no.name stamps on the outside. Alternatively you can flatten the wear by grinding with wet and dry papers on a glass plate
Halo
10 Nov 2009
Wetherby
If it’s a a Vetus see through top strainer I would start with that.
The top expands and shrinks a lot with temperature ( general issue with plastic). Others have said about using Vaseline to help o ring seal. I also put a rag on top then pour on some hot water to warm the top. It then goes on much better and seals nicely. Trick also works for removing.
Daydream believer
6 Oct 2012
Southminster, essex
Better to pour boiling water on to an old tea towel & hold that over the cap.It retains the heat more evenly & for longer. Same system for removing stuborn hoses from tails.
