Laundryman
Just fitted one today. Fairly straight forward but I've had a problem with the 12v supply. I started with the best intentions. Oversize cable, crimped joints with heat shrink. In line fuse and isolating switch. Sometimes it worked, sometimes it didn't. Bad connection somewhere I thought and checked everything. Couldn't find a problem so started eliminating joins in cable. I'm now at the point of having a straight run of cable from the power directly to the loo and it works every time. Voltage at the loo 13.2 volts. Can these things be so sensitive to voltage drop so as to make them erratic? Have I just got a faulty loo. As it stands at the moment it works perfectly. My next plan is to run the power supply through a proper fuse box ( as opposed to the inline fuse ). And if it's still reliable I will leave it at that. Any thoughts please? Thanks. Alan
