AluciaOfDart
New Member
Bonus level has been achieved and I have my permanent mooring in Dartmouth! The thing is, I need to understand it better. So let me describe it and the bit I need to get to grips with.
Boat
Alucia's 6 tonnes or thereabouts of Mitchell 31, with stub bilge keels. She has a metre freeboard, two fore cleats and fairleads and a samson post. Bow roller is already filled with anchor. Aft she has two stout mooring posts on each corner of the transom, and she has a midships cleat each side. She is tall, with mast and radio aerial above the cabin.
Trot
The trot has a ground chain of 18 metres fixed to the bottom fixtures/rings of two non swivelling buoys on stout risers. Through the buoy passes a solid steel rod, and the top is a non swivelling ring. Between the two buoys, at surface level, is a trot rope which is 17+ metres long. That trot rope must not be removed, It is a condition of the mooring that it is present at all times.
Alignment
The trot is misaligned with the ebb and flow of the river. The prevailing westerly winds blow across it, too. In other words everything on the trot is at best diagonal for air and water flow.
Spacing
I estimate there is half a boat's length more than Alucia's LOA between my string of trots and the next. Manoeuvring room is at a premium. I know I can drift down at 90º to the trot lines under control because I have, but it's tight.
Current
I estimate a 2 knot current at peak tidal flow, perhaps more
Mooring direction
If I look at the other boats, not one is moored facing downriver, but our river is tidal. So they must either all have come in on an ebb tide, or been prodigious seamen to moor with the flow on the flood. I doubt many of them are that skilled. Obviously facing bow on to the maximum likely current is a good idea, but not at the expense of seamanship, surely?
Tackle
On each of the buoys I have two lines. A metre of chain is shackled to the buoy and buoyant line reaches past the midpoint of the trot. The lines are long enough to meet with enough spare to make fore lines fast to aft lines when Alucia is not on the trot
So what's the advice I need?
Assume I am the only boat on this trot, though it is intended for two, and assume I am on the windward side of the trot line, being pressed past the mid point by the wind and the tide. I need to let my bow and stern lines go but make them fast to each other, and clear them and the trot rope, a rope that is slack, not buoyant, and thus in very close proximity to rudder, prop, and to the potential for going between my stub bilge keels and the main keel.
I can do it, but I'm not sure I can do it as well as some of you can, and I'd like to benefit from your expertise, please.
I'd also like your thoughts on picking the mooring up in the most effective manner. I am almost always single handed to moor and unmoor. I do have a bow thruster, but I don't want to rely on it. I can see the use of it, but the minute I rely on it will be the minute it chooses to raise two fingers to me and giggle.
If there is another boat on the trot I can do it all with ease. Without one there It is less straightforward. Losing the trot rope would be ideal, but isn't allowed
Boat
Trot
Alignment
Spacing
Current
Mooring direction
Tackle
