MattS
I'm fitting a new shaft anode to my prop shaft. I'm fairly sure the size (1") is correct, as the next size up is several mm larger and I think would not make solid contact. However I notice that the two halves of the anode are not touching with how I've tightened it up currently.
Is this correct, or should the fit be completely snug and two halves be completely touching for it to be fitted correctly?
