Does it work: yes with out a doubt
Is it a fancy bit of kit that makes life easy: same again
Can you give a link to anyone who's actually got it working? If you Google for waterlog watermaker you'll find countless stories about this scam.
From what I recall of reading about this a few years back, they never solved the engineering problems inherent in their solution. Ruptured hoses, sized bearings, leaky joints etc etc. Poor quality control just about killed any chance of it working.
If this was part of the problem then modern engineering and decent quality control would solve the issues.
I did note they were using dated and hardly user friendly technology - a stainless tow rope would be a real nightmare, in my humble opinion - why not an anti torque dyneema.
I note a lot of discouraging negativity in the posts. We seem unable to open our minds to novel ideas.
We have an Aero4Aquagen. At 10 knots it will produce 10amps and 10 amps will drive our desalinator and produce 60l of water/hr. The trick is using that same energy, cutting out the middle man (electricity) and using that energy to desalinate water. Lose 50% through inefficiency and making 30l per hour would satisfy most cruising yachts. I also note the comment - who will tolerate a loss of 1 knot - (not sure where the 1 knot comes from) but most cruising yachts would welcome the ability to make 30l of fresh water an hour - and would quite happily sacrifice 1 knot - its not as if they have a schedule.
Our LVM aerogen is pretty simple and based on pretty old technology - today we have access to much better REO magnets that (thanks to China) are cheaper. I might have thought a towed generator made today (think of Watt and Sea) might be more efficient.
In the same way a towed water maker, along the lines of Waterlog, might be feasible.
I might encourage the makers of Torqueedo (and its clones) to consider looking at the market currently serviced by Watt and Sea I would welcome anyone who sticks their neck out to develop something making an alternative to electric powered desalinators (Rainman being one example - though hardly novel).
Our first GPS had an accuracy of 100m (we still have it, it still operates with that same accuracy) and would have been totally useless as a chart plotter it simply produced lat and long) - how things change.
If 'Waterlog' produced fresh water - there is the germ of an idea and process that needs to be supported - not damned. Possibly the attitude of the development team might need to change - if the posts above are correct - but given the attitudes here - I'm not surprised they are hiding. Maybe someone else needs to pick up the idea and run with it.
Jonathan
Apology, 10amps 30l, 60l i a bit more than twice that, don't recall exact figure.
Cut through the media twaddle (sadly published and promoted by the manufacturer as well) and what youhave is reverse osmosis driven by a pump powered by a propeller.
"working without any power" now theres the bollox, try telling that to the skipper that sees a loss of over a knot when its deployed.
Similarly sized towed generators give you 4A if you're lucky. 5 litres per hour through a reverse osmosis system with 50W sounds ... optimistic.
