Is my speed log showing incorrect speed?
muckypup
16 Sep 2005
Up the river Crouch on sunday, about 3 hours after high tide going upriver, my GPS was showing SOG of 7 knots, and the river I believe would have been running out at 3 knots. Should my speed log have been showing 10 knots? It was actually only showing 4.5 knots....
S.
flaming
24 Mar 2004
Surely you can tell the difference between 4.5 and 10 knots just by looking at your wake!!
mortehoe
19 Sep 2006
Ergo the esturine flow was
2.5 knots as recorded by your speed log /forums/images/graemlins/smile.gif /forums/images/graemlins/smile.gif /forums/images/graemlins/smile.gif
muckypup
16 Sep 2005
Interesting thought! I will try that next time I'm out.
I should also try and get out at slack water time, so the SOG & log should show the same?
S.
flaming
24 Mar 2004
The normal way of Log calibration is to do a run at a constant speed between 2 objects at a known distance apart and then use the distance travelled rather than the speed to calibrate. Either mile transits or buoys are good for that. By running both ways and doubling the distance you eliminate the tide effect.
Be careful of only calibrating your log at slow speed. The calibration is normally done by a percentage basis, so you may want to do several runs at different speeds to check that the percentage out is the same, and if not choose the best fit.
muckypup
16 Sep 2005
The normal way of Log calibration is to do a run at a constant speed between 2 objects at a known distance apart...
That's an excelent suggestion. Next time I'm out I will pick a couple of bouys and try this.
S.
jonathankent
23 Dec 2005
Cornwall
Log only shows your speed through the water... regardless of any tide whatsoever.
For your GPS to be showing 7kts and you believe an adverse tide of 3kts, you have got one hell of a quick boat to achieve that! /forums/images/graemlins/smile.gif
If your log was correct of 4.5kts, against a 3kt tide your GPS would have only shown SOG of 1.5kts.
Personally, I suspect the GPS wasn't functioning spot on that day... or the tide was doing the opposite to what you believe /forums/images/graemlins/smile.gif
muckypup
16 Sep 2005
That's only 10 knots, Harlequin is good for 13-14 flat out.
We were well faster than that as we went down river about 6 miles, and at 1.5 knots it would have taken us some 4 hours to get back (the entire trip was only 2.5 hours)
Definately going out as SOG was showing 11 knots downstream at only half throttle.
Steve
jonathankent
23 Dec 2005
Cornwall
Ahh.... just looked at your profile.... a mobo - should have known really, heres me thinking you were sailing /forums/images/graemlins/smile.gif
Well, knowing what the boat can do... now I tend to lean more to the log requiring either a clean or a recalibration.
muckypup
16 Sep 2005
ooo no, all those ropes and cloth and tacking.. far too complex for me /forums/images/graemlins/smile.gif
S.
