webcraft
Teleflex single lever side mount, fitted 2006.
it's been getting increasingly stiff to get into gear. Now the boat has been sitting on the hard for nearly 2 years and it won't go into gear at all. Instead the 'neutral' red button automatically pops in with a loud, hard 'snick' when you reach the normal gear engagement point.
The handle is stuck on the splined shaft as well, so I can't get the cover plate off to undo the screws and remove the unit from the inside of the locker it lives in to have a good look at it.
My gut instinct is to saw the handle off and remove the unit, throw it away and order a new one - but thought I would first see if anyone here had experienced as similar problem /set of problems and solved it ?
- W
- W
