andy59
The compressor is very noisy and the cooling fan seems to need a push start . I am hoping to be able to repair rather than replace as a replacement is over £1000
Is the inlet pipe (larger lower) getting cold and the discharge (smaller higher) getting hot. Might simply be out of gas. The cooling fan might be controlled by the discharge pressure, so if this doesn't increase (lack of gas) it doesn't start.The compressor is very noisy and the cooling fan seems to need a push start . I am hoping to be able to repair rather than replace as a replacement is over £1000
The compressor is very noisy and the cooling fan seems to need a push start . I am hoping to be able to repair rather than replace as a replacement is over £1000![]()
