tri39
I use solar panels without a regulator when living aboard. The fridge (also without a thermostat, just turned off at dusk), consumes any surplus power! However I do disconnect the panels (apart from a 10wt panel in the winter) when I leave the boat, you do need to remember! I also feel the panels confuse the Adverc controller and should probably be disconnected when motoring altho I usually forget.
I use panels and no windmill in the Med, motoring most mornings plus blistering sun provides enough power for my modest needs.
Leaving all your panels connected all winter without a regulator will be too much for your batts.
