Nautorius
I am asking if I am being too picky about what jobs to do in renovating a boat. I have looked at several projects over the years and have come up with a list of modern requirements which a boat should have. If the boat has the facility but is old, and still usable I consider it OK.
However when a boat gets over 30 Years old without remedial work then I consider all systems only fit for the bin. This is based on the problems of finding replacement parts to mend broken items and the complexity of fitting.
The latest boat I looked at I was hoping to buy, do some remedial work to make her sea worthy, then upgrade systems over time. However one look at 40 year old electrics system and I was screaming. I just do not think it is safe to put any power through the cables and although the old light fittings seem OK, I would need to take them apart to check. The fuse box would have been condemned long ago in a house and the positioning of this wiring (attached to old wooden frames) means the slightest glitch and the boat is ablaze. So the only option is to rip all out and complete re-wire to modern standards and modern fittings where required.
The Fuel System was frightening. The diesel tank was an old stainless steel tank (20 years old) and had been moved to under a rear bunk without much ventilation. The original petrol tank was still in place with all the pipe work, the pipe work to the diesel engines was rotten, the connections of the pipe work where rusty, the positioning of the fuel tank was wrong….only option is to rip all out and start again.
The Gas system was very scary and would not pass my safety test, never mind the BSS requirements. Only option was to rip all out and replace with diesel fired heating and cooking (personal preference though more expensive)
The Framing was sound as is Aluminium and Hard wood, the hull is sound except for the wooden chine rails which are rotten and bolted through hull so would have to be replaced or 20 small holes may let in a lot of water. Best option to slurry blast the aluminium hull and deck and start again with fresh epoxy and paint. The Cabin tops were solid (ply) but 10 years old. The cabin sides were all rotten (20 year old ply). Given the 10 layers of non slip applied to the cabin tops and the difficulty of doing the sides with the top in place I thought it best to replace all things. Easy enough as only screwed to the Aluminium and hardwood frames and all screws easily got at (great!)
The steering system was seized and the ‘hydraulics’ rusted. Only safe option to rip out and replace. The Engines may be OK, who knows but until electrics and fuel sorted I would not start them. Anyway they are too small compared to original spec (replaced 20 years ago) so would be replaced anyway.
The water system was actually OK, but decrepit and new piping and tank needed and a better position could be found. The two sinks and toilet were classic but OK, just a service to the loo. The calorifier probably bit the dust in the late 80’s but has been left to rot down nicely….need new calorifier and piping all around boat.
The wooden floor in the cockpit and cabins was rotten, and needed ripping out and replacing but the actual hand made furniture was in great condition (probably too heavy to remove).
In Summary, I need new electrical system and appliances, new water system and calorifier, new gas/diesel system, new fuel system, new steering system, new cabin sides and tops, new floors and well the only stuff remaining needed renovating i.e. hull and interior furniture.
So surely it is not ‘renovation’ that is required but a new boat building!
Have I got it wrong?
Cheers
Paul
/forums/images/graemlins/laugh.gif
Cheers
Paul
