PaulRainbow
According to who
Good to see you back to your true self Roger, the act must have been terribly difficult to have kept up for a whole month.
According to who
So we can put the shore power wires into any old connection, the live doesn't actually have to go in the live terminal, it can go in the Earth terminal ?
No, of course it can't, some things have a set way of being done.
Feel free to wire your boat up any way you see fit, it's your boat.
Terminology for the non technical can be confusing or designed to confuse.
Going back to the neutral / protective return wire connection of the supply device its is also connected to a metal spike inserted in the earth/ ground/ soil next to the supply device (electrical substation). This is why it id called earth or ground.
In a domestic electrical set up you will also have a earth / ground spike at your hone the connects the protective supply wire in the supply cable.
This "earth/ground" connection at the substation and at you house provides a second path for any leakage / short to a metal case back to the neutral at the upply device (substation). In the case of a boat this earth/ground spike will become any conductive metal in contact with the sea water .
Roger,
This system using a ground spike at ones a home is the least common system used in the UK. Probably only used in rural areas where the local distribution is overhead. It is termed a TT system ("T" from the French word " terre", meaning earth or ground) because a direct connection to the earth is made at each end.
More common is TN-S, where the earth and neutral are separate conductors ( hence the letter "S") in the supply cable, (The earth being traditionally the lead sheath)
Now that lead sheathed cables are not used ( or even made ??) TN-S is replaced by TN-C-S in which the supply cable is just two core. One core being a combined ( hence the letter "C") earth and neutral. The earth for the house installation is then a separate connection made to the combined conductor at the cable termination..
( should perhaps add that a TN-C-S system is not allowed for the pontoon supplies in a marina because a discontinuity the combined conductor would lead to a very dangerous situation)
Thanks for that Vic
Well it been nearly 40 year since I owned a house in the UK so things have changes.
My current main house was built in the 1960's so may be still the old system as we do have an earth spike.
If I remember correctly my house in the UK did not have an RCD but my house in South Africa did. We also have to have our house inspected when sold to ensure the electrical installation complies with the current regulations.
I do wonder why the separate earth wire/connection was changed are the main supply cables steel wire reinforced ,ours are and that carries the earth wire.
I know as our local mulispiacity who distribute our electricity to us had to renew our main supply cable to us.
Have you got your answer now VicI'm looking at buying a 3000w inverter most have a earth connection, talking to some who have them the earth isn't connected,
what the view on connecting the earth and where too ?
I am not up to speed on it but I believe the resistance of steel armouring (8 times that of copper) can be the problem
Yes but the area of the reinforcing steel wire would tend to compensate for the lower resistivity of the steel.
I checked on how my incoming cable is connected and the steel reinforcing is in fact connected to the earthing bus in the that all the house earth wire are connected too.
Typically, the cross-sectional area of the steel armour will be 3 to 4 times the area of the conductors.
Carbon Steel is better than Lead and far better than sea water or ground soil so your point is
You mentioned the area of the reinforcing wire, noting that it would compensate for the lower resistivity of steel. I supported that statement by noting that the area of the armour is greater than the conductors. But you then respond "so your point is", which I feel is confrontational. Post 81 seems to be correct!
What has South African house wiring or 40 year old UK domestic suppl
They say "a little knowledge is dangerous"
I wonder what a little 40 year old knowledge is![]()
Anyway, what has 1960s South African house wiring got to do with the OPs question ? ?
Because both are based on the same standards as most South African stands are based on ISO published standards
You mean people without a registered professional qualification and practical experience.
Nothing as I was answering a posting made by VicS so why are you getting involved.
The OP has not come back so he must have his answer somewhere else
I mean people who have no real World experience of current procedures methods, regulations etc.
I was answering a question by sailaboutvic, why are you getting involved ?
Oh, hang on, it's an open public forum.
Every single time, without fail, there is a thread about inverters on these forums they turn into a total and complete fiasco, by people who don't understand how they should be installed. Every time.
In my view it becomes a fiance when you start criticizing other peoples approach as it seems the only way is your way and yours is the only correct way and everyone else if wrong and dangerous.
No, it's becomes a fiasco when people question that Earth connections should not be connected, when people state that an anti fouled keel makes a suitable Earth, when people claim that their way of wiring equipment is better than the industry standard, as set out in the current ISO, etc etc etc
I have not advocated "my way", i have advocated the way that manufacturers and all industry standards and regulatory bodies say thing should be done and they all say the same thing. There are only tow people on the forum who have said different.
Anyway, as you'll argue in an empty room until the cows come home, i'll wish you a pleasant weekend and sign off on this thread.
Out.
This demonstrated the difference between a technician who blindly follows the industry standard, and a Design Engineer who asks "is there a better way" and that better way then becomes the standard in time sometimes a long time.
That's just totally ridiculous, even for you.
No one in the industry ignores the manufacturers wiring instructions, the current standards and the regulatory requirements. That's territory for internet forum armchair experts. It's also one of the most arrogant things i've read for some time, where you think you know better than all of those entities.
I happen to know sailaboutvic could not afford/justify the cost of a Vectron inverter so rejected your recommendation. Its his choice.
