Gordonmc
By the look of the galley the boat looks to be quite modern so it may be possible to speak to other owners or the manufacturer to find out where gas bottle stowage is normal. I would go with others in saying it shouldn't be in a battery compartment.
I had to install a gas supply to replace a US propane system - rubber pipe throughout and humungous tanks on the deck.
There was no dedicated gas locker so I mounted a fibreglass box big enough for two 3Kg bottles on the after deck. I used plastic encapsulated copper pipe in one run to the galley with only one bulkhead fitting where the pipe enters the aft cabin. I also installed a supply solenoid in the run so the gas can be turned off at the bottle from the galley.
The OP has done the right thing by asking pertinent questions before starting the project. I would advise that the location of bottle stowage has to be settled before all else.
